djlutz
Actualizaciones del PCLC (II)
Nueva versión de PCLC 5.13F :cervezas:
Descarga:
PC Lap Counter v5.13f
·Scalextric digital C7042: you can use old powerbase C7030 to detect Pit in/out.
·Add "Nothing happens" for the out of fuel option.
·Pitstop detection with Phidget interface: change the delay of 2 sec to 1 sec.
·Race setting: Set race name to grand prix name when championship selected.
·Championship classification: add the total laps completed of all GP in the sort order.
·Scalextric Digital C7042: impact of the fuel on power: improve of the power calculation so that driver can get 100% power.
·Statistics Board: in the “driver best lap” panel add a graph to show the lap time and the total throttle used for each lap.
·Fix this bug (concern false start and race clock)
·5.13c: fix this bug (concern heat editor and car changes).
·5.13d: fix bug : race setting window: when you select a championship in the dropdown list then the segments generated by the heat editor disappeared !
·5.13e: all interfaces (scalextric digital, scx digital, DS racing, etc...): disable the possibility to close the interfaces window via the “x” button but you can still close via ALT+F4.
·5.13f: fix bug: Trackcall during a Pit stop : if you selected “pause the race” for the trackcall then after the race restart the pit exit was rejected by PCLC.
NUEVA ACTUALIZACIÓN v5.18
Pincha aquí para descargar Pc Lap Counter 5.18
· Display a special picture (in place of the car picture) when a driver is in the Pit lane and received a Stop & Go penalty
· You can now use the pace car / yellow flag feature with all systems (with Slot.it oXigen,Scalextric C7042 and Pb-Pro you can reduce the cars max speed during the yellow flag).
· Otros
La primera opción es petición de este foro, la segunda es una opción brutal para los sistemas oXigen y SSD.
Para Más Información:
http://www.pclapcounter.be/news.html
NUEVA ACTUALIZACIÓN v5.24
Para descargar:
http://www.pclapcoun...Lap_counter.exe
Novedades anteriores no reportadas anteriormente:
5.23c:
Fix a bug in the Stop & Go feature
5.22c:
Track setting: add the possibility to change lanes color. (Ole para los Daltonicks, ahora podremos escoger el color que mejor "vemos").
5.21e:
Display setting: you can use the lane background colors as background colors for main screen.
5.20f:
New skin “need for speed” (mola, para los frikis como yo del NFS)...
Race detail reports: Columns order and size are now saved ( ver si el del bocata dice algo al respecto....)
5.19k:
5.19k: Ninco Digital: you can change the minimum pit stop time.
5.19k: Ninco Digital:if the ND lap time is under the minimum lap time of the track then will look at the PCLC lap time and if the PCLC lap time is not under the minimum lap time then PCLC will accept the lap and take the PCLC lap time and display a message.
