El semáforo, y más, que Roberto sueña.
Escrito originalmente por Guest thibaut en 14 de Febrero del 2006
Un compañero holandés (¿o alemán?), Snellemuis, acaba de colocar en slotforum.com una información muy interesante: se ha construido un puente semáforo/cuentavueltas que conecta a un PC. Además, ha colocado un link a su página para que podamos verlo. Este es el mensaje:
Hello everybody,
A short intro:
I own a SCX Digital set since december 2004 with a lot of extra track pieces (now 2006 I own the GT and DTM set with extra cars). I made my own starting light, with two (and expandable to four) lapcounters, which also can be connected to a PC with software. The PC can start the four red lights one-by-one and all 5 lights go to green .... and the race is of. The starting light can also be controlled by hand through switches, which are on the back of the startinglight.
I also made a track piece which can recognize the cars (even if they change lane) so the fastest time can be recorded by PC software. This is done by four InfraRed switches.
I also made a Ninco Safety car compatible on SCX Digital.
SCX Digital let me have a lot of fun, so I put some movies of my track on my site (it is in Dutch, sorry).
This year will be great too, with the chicane, new cars, oil track etc.
I opened myself a handcontroller and removed the spring so that my safety car is a challenger on my track now.
I hope you enjoy the movies. I know the quality can be better, but because of my homepage space and the long download for you, I reduced them.
I hope this forum for SCX Digital will expand tremendous, so everyone can enjoy slotcar racing ... but specially on SCX Digital.
movies on: http://www.huize-denheijer.nl/alexslotracemovie.html
¡A ver esos electrónicos, que se pongan las pilas!
Otra demostración de que, como decía en otro post, el Digital System está cuajando por todas partes.
Se me olvidaba. Hasta ha digitalizado el Safety Car de NINCO.
Escrito originalmente por Robert007 en 15 de Febrero del 2006
Jajajajajajajaja, [smilie=eusa_clap.gif] [smilie=eusa_clap.gif] [smilie=eusa_clap.gif] [smilie=eusa_clap.gif] [smilie=eusa_clap.gif] [smilie=eusa_clap.gif]
Estimado Thibaut, muchisimas gracias por demostrarme que no sueño tanto, que te crees? jajajajajaja, como se lo monta la gente.
Estoy todavía visionando los clips, pero el primero que he visto ha sido el del semaforo-cuentavueltas-puente, vaya pasada.
Bueno y bueno, lo de Safety Car de Ninco te tiene que haber puesto los ojos como platos, verdad?.
Intentaré descrifrar el mensaje en ingles con la "Enigma" dado que mi ingles, se reduce al que aprendí con "Centauros del Desierto" y algunas más de ese tipo, aunque algo entiendo.
Un saludo y seguire comentando. [smilie=drink.gif]
PD.- Refrendo lo dicho por Thibaut, los compañeros electrónicos que se pongan las pilas y que sean alcalinas. [smilie=5bullwhip.gif] A diseñar.
Thibaut, apuntate así como media docena de puntos (aunque no sepa que rifan, jajajajajaja), menudo circuito tiene el amigo verdad?.
He entendido que el cuentavueltas del puente lo ha realizado con infrarrojos, aunque pienso que no puede ser así, no lo se.
A día de hoy y con lo que sabe la gente de la página, estoy seguro que alguno es capaz de adaptar cualquier champiñon (crono, cuentavueltas y semáforo) a un puente y después, hay que buscar a un artista de la maquetación para que tenga un diseño elegante, moderno a la par que digital. Si bien el crono y el cuentavueltas necesitan la adaptación digital, el semáforo puede estar como el del analógico, es decir, "pulsar botón" y fuera. Más complicado es lo de la gasolina, aunque comprando 2 modulos vete a saber.
PD.- Viendo el circuito de los videos y la escasez de material que tenemos ahora de curvas interiores y bordes de todos los tipos en color rojo, sabe alguien de alguna tienda extranjera que mande compra a domicilio a las Españas? Vamos si te pillas algo por internet para el Ipod Nano o el que sea en EEUU o USA y lo tienes en 3 días, creo que tenemos que buscar soluciones alternativas a las carencias que tenemos y adquirir SCX en el extranjero, no?
Escrito originalmente por Guest MollyPGR en 15 de Febrero del 2006
Vamos a ver, por lo que entiendo, el amigo hace el cuentavueltas con sensores de infrarojos para dos coches solamente, lo cual no es complicado siempre que sean de colores distintos. Con un sensor GP2D2 o un GP2D12 que son de infrarojos y de cerca te distinguen bien colores no es complicado. El problema vendría en cuanto tuvieras dos coches iguales, la cosa se complica por tener que distinguirlos.
En cuanto al semáforo, con un PIC 18f452 o incluso menor, que este soporta tren de pulsos PWM y señal analógica, se puede hacer el semáforo que solo le tengas que dar a un interruptor para hacer la secuencia de semáforo, incluso como en la realidad con tiempos aleatorios de encendido. A ver si cuando acabe los exámenes os pongo un semáforo para que lo veais, que ya tengo un placa por aquí montada.
Saludotes
Escrito originalmente por Guest thibaut en 15 de Febrero del 2006
Lo hace por infrarrojos y vale para cuatro coches. Por lo que acaba de añadir en un nuevo post, cada coche lleva una placa de alumino colocada en diferente sitio (izquierda, centro izquierda, centro derecha y derecha). Así, con cuatro sensores en cada carril, detecta e identifica el paso de los coches.
Visto esto, la cosa deja un poco de ser tan interesante.
Seguiremos informando.
Ya puestos Thibaut, voy a pensar en algún inventillo chapuril. Lo que pasa es que a los precios de los accesorios, una broma sale cara.
Confirmame una cosa si tras la salida del Pit se ponen las 2 pistas de conexiones del Crono y el Cuenta-vueltas, pasa algo? hay incompatibilidad?.
Te lo digo porque el objetivo sería hacer un puente con el semáforo, el crono y el cuentavueltas-posiciones existente.
Como ves sumales semaforo+ 2 champiñones con ampliaciones y es bastante caro, hay que pensarselo mucho [smilie=arcade.gif], dado que los accesorios que tengo los dejo como estan.
Escrito originalmente por Guest allopez en 15 de Febrero del 2006
Es flipante lo del pollo aleman!! [smilie=eusa_clap.gif] [smilie=eusa_clap.gif] La verdad es que viendo lo que hacen los que saben.... [smilie=cry.gif] [smilie=cry.gif] el pueblo llano tendremos que conformarnos con gastarnos el sueldo comprando los accesorios originales que nos proporcione la gente de Tecnitoys [smilie=eusa_wall.gif] [smilie=eusa_wall.gif] y así poder disfrutar un poco [smilie=arcade.gif] [smilie=arcade.gif]
Si alguien se anima a hacer este tipo de cosas por encargo para los inútiles del bricolaje... [smilie=dontknow.gif]
[smilie=drink.gif]
Escrito originalmente por Guest cardi en 15 de Febrero del 2006
Jolin MollyPGR, con el PIC te haces la centralita del PitBox [smilie=biggrin.gif] ¿No es matar moscas a cañonazos?
A mi se me había pasado por la cabeza hacer algo sencillo, con un 555 y un contador o algo así, que encendiese unos leds uno a uno y después los apagase de golpe o los pusiera de otro color con un toque de bocina... A ver si tengo algo de tiempo y le doy una pensadita.
Robert, yo creo que no hay problema, al contrario funcionará 'mejor' al ser la distancia de la linea PL más corta. Yo tengo el cuentavueltas justo después de la recta del Pit y va bien.
Escrito originalmente por Guest faramalla en 15 de Febrero del 2006
Menudo tipo este Aleman se lo ha currado [smilie=drink.gif]
Yo hace unos años como cinco o seis vi en un Barco que vino a Cartagena a reparar el Capitan con el jefe de maquinas tenian un scalextric montado en una sala del Barco y me quede alucinado de lo que tenian puesto eso parecia como una maqueta de Ibertren de las cosas que tenian puestas.
El Otro dia en una tienda de Cartagena la unica que hay especializada en esto que sellama Stuka, un padre con su hijo estavan hablando con el chico de la tienda si ellos hacian chapuciyas a los coches y demas Bueno lo de chapuciyas segun como lo mires porque lo que decia el hombre era que tiene un becino en la playa que le ha dicho que en Alemania hay tiendas que te montan lo que sea en un coche seha del sistema que sea el queria comprar el Safety de Ninco y que la tienda se lo hicieran digital como otras cosas mas el hombre de la tienda flipo yo me quede alucinado, por eso digo yo que mi compa de fuerza Robert tiene razon y gual hay que buscar tiendas en el estranjero para tener un scalextric asi como el germano.
Saludos [smilie=user.gif] [smilie=eusa_clap.gif]
Escrito originalmente por BOMILCAR en 15 de Febrero del 2006
Faramalla, he leido (ahora no recuerdo) un anuncio de una tienda de slot que preparaban coches, en cuanto lo encuentre lo pongo.
De todas maneras creo que cuando hablan en de preparar coches, lo que hacen es cambiar ejes, coronas,etc....
El colega holandés o alemán, ya ha colocado las fotos. Lastima que sólo valga para cuatro coches. Aunque, yo pienso que sí se podría hacer para seis.
http://www.slotforum.com/forums/index.php?...showtopic=13646
Escrito originalmente por Guest charmander en 16 de Febrero del 2006
Creo que el colega no ha dejado ni un Euro para el recibo de la luz !!! [smilie=biggrin.gif]
Bravo thibaut [smilie=eusa_clap.gif] por la Informatikation [smilie=drink.gif]
Escrito originalmente por Guest MollyPGR en 16 de Febrero del 2006
Cardi, obviamente no sería su único uso. Llevo tiempo pensando en varias cosas para hacer y se me ocurrían unas cuantas, semáforo, velocímetro. Que se enciendan luces al pasar un coche por una zona....
Lo que pasa que hasta que monte la pista permanente, no tengo claro lo que quiero, así que hasta entonces no pienso hacer mucho más.
La solución del colega aleman le puede dar bastantes problemas con los sensores que ha usado, son CNY70, que fallan más que una escopeta de feria estando tu borracho. Esos sensores se basan en tener emisor (el pilotito azul) y receptor (el negro) y en función de la intensidad luminosa que les llegue te dan una señal de salida.
Distinguen bien entre blanco (que refleja todo) y negro (que absorve todo). Por eso el colega alemán se la juega a hacer convinaciones para que con dos sensores por carril poder detectar cual es cada coche.
Saludotes
