PB6 Pro se ma ha muerto
Escrito originalmente por Falcodm en 2 de Abril del 2008
Hola,
Os explico, yo ya había actualizado la PB a la versión 1.6 y esta noche quería actualizarla a la 1.7d, cuando he ido a hacer el proceso me ha dado error Imagen y la pantalla de PB se a quedado azul con los cuadraditos blancos, ¿¿¿Os a pasado alguno, se puede hacer algo???Imagen
Bueno pues eso, que para una noche que se me ocurre montarlo, vaya manazasss
Hello
Os explained,
I had already updated the PB to the version 1.6 and this night I wanted to update it to 1.7d, when I have gone to do the process it has given me error and the screen of PB to could only blue with the white cuadraditos, to some past, is it possible to do anything??
Escrito originalmente por RikoRocket en 2 de Abril del 2008
Reload it. It sounds like a interruption during programming.
Cheers
Riko
Escrito originalmente por Falcodm en 3 de Abril del 2008
RikoRocket escribió:Reload it. It sounds like a interruption during programming.Cheers
Riko
Gracias por contestar tan rapido Riko.
he podido hacerla funcionar actualizando a la 1.6 pero cuando quiero actualizar a la 1.7 me da el siguiente error.
Connected to \\.\COM3 at 19200
HEX: 7 days old, INHX32,18Fcode+cfg, total=23362 bytes.
Searching for PIC ...
Found:18F 252o/452o
Could not write
ERROR!
Thanks for so rapid Riko. answers I could have made her work updating the 1.6 but when I want to update the 1.7 it gives me the following error.
Found:18F 252o/452o
Could not write
ERROR!
Escrito originalmente por RikoRocket en 3 de Abril del 2008
OK, three things.
If the .HEX code has an address too long, it will not work. Make sure you put the .HEX code in a folder directly from "C:" drive if possible.
I understand you already made the update from 1.1 to 1.6? If so the cable should be good. Otherwise I would suspect that the transmit side is not connected. Are you using a RichG cable?
Last. I dont want to say this. Are you programming a PB-Pro? Ordinary PB cannot be updated, there is a hardware modification inside. (sorry for asking!)
Escrito originalmente por M1K3LSLOT en 5 de Abril del 2008
A mi me paso lo mismo y lo copie el codigo HEX en el portapapeles de windiows y una vez abierto el tinybld193 los pegue en ewl terminal,
en la version 1.7 c y 1.7 cms funciona en la 1.7d no lo se no conozco a version.
Riko que pertenece a la simple H?
To me the same way and copy the code in the HEX clipboard windiows and once opened the tinybld193 the paste at the terminal,
In the version 1.7 cy 1.7 cms works in 1.7d not know what is not a version.
Riko belonging to the simple H?
Escrito originalmente por RikoRocket en 6 de Abril del 2008
There was a minor bug in 1.7d, the PB could corrupt the display. I have released version 1.7f This version overcomes the bug. If you had problems loading 1.7d try the new version.
I have a version dedicated to simple-H, if anyone needs this version please send me a personal message.
Escrito originalmente por M1K3LSLOT en 6 de Abril del 2008
¿Que diferencias hay de 1.7 c , 1.7 cms con 1.7 f?
What is the difference of 1.7 c 1.7 cms to 1.7 f?
M1K3LSLOT escribió:¿Que diferencias hay de 1.7 c , 1.7 cms con 1.7 f?What is the difference of 1.7 c 1.7 cms to 1.7 f?
Essentially the code is the same, always the suffix "ms" adjusts a single power supply plugged in to be the maximum overload level so that with a master slave (maestro-esclava) you can run from a large power supply. A better description of this "ms" code would be use this when you are not using standard superslot power supplies. (David Nene, you use standard power supplies so the standard f code is good for you)
SIMPLE EXPLANATION:
"c" to "d" added an option to disable lane changers for up to 9 secs after the start of a race
"d" to "e" was setting up the trip points for the simple-H modified PBs.
"e" to "f" was trying to fix a bug that someone found where the PB would stop
COMPLICATED EXPLANATION:
(Software engineers only)
; PBPRO17a.ASM ;
; EEPROM adresses 20h to BFh stored in shadow RAM which is then ;
; used to set race and control parameters via the PB keys or ;
; the Aux In PC link. ;
; Version number specified by 3 characters (stored in EEPROM): ;
; primary and secondary release digits & edition alpha. ;
; If the EEPROM values differ from the hard coded values then ;
; automatically load EEPROM with defaults. ;
; pc_throttle_map command now writes directly to throttle map ;
; RAM rather than EEPROM. Power to track is no longer disabled ;
; for this operation thus allowing the throttle map to be ;
; modified on the fly. ;
; Three pace car Aux In short commands added: ;
; PACE CAR ENABLE, PACE CAR LC & PACE CAR SPEED ;
; Start sequence made adjustable between no start sequence, ;
; standard start sequence (as per SSD) and random delay for ;
; beep (between 1.9 and 3.7 secs). These options are selected ;
; via the pc_sel_start_type Aux In command. ;
; Aux In commands added to disable and enable selected cars. ;
; Auto throttle calibration routine added that can calibrate ;
; all 6 throttles simultaneously. Initiated by squeezing a ;
; throttle immediately after entering Set Controller mode. ;
; USED FOR WORK SOCIAL ON 08/02/08 ;
; PBPRO17b.ASM ;
; pc_read_eeprom command changed to pc_read_memory where the ;
; first 32 bytes transmitted to the PC are from the first 32 ;
; bytes of EEPROM, the remaining bytes are from shadow RAM. ;
; Changed auto throttle calibration to the following: ;
; a) trigger from a low to high setting to select ;
; b) return to a level below 10h to start calculating minimum ;
; c) then goto a level above 27h and hold to calculate maximum ;
; b) a single beep confirms when each throttle is calibrated. ;
; Short beep added to confirm receipt of long commands. ;
; RELEASED FOR EXTERNAL EVALUATION TO RICH & COLIN ON 16/02/08 ;
; PBPRO17c.ASM ;
; Assembler directive PWR_STAGE_TYPE added where 0 = standard ;
; PB Pro and 1 = Simple-H PB Pro. Standard PB Pro overload ;
; settings are now fixed at the defaults of 2.5A for single ;
; supply and 3.5A for dual, with both having an overload ;
; timeout of 250ms. The Simple-H version only requires a single ;
; power supply connection with the overload level and timeout ;
; being stored in EEPROM. ;
; The overload level and timeout settings have been removed for ;
; standard PB Pro and there is no longer restricted entry to ;
; these settings for the Simple-H version. Both versions have ;
; a current consumption display within the CONFIG menu. ;
; The EEPROM view screen within the CONFIG menu is now only ;
; available if the code is assembled with DEVELOPER_MODE = 1. ;
; In SET CTRL mode go direct to parameter select when a ;
; throttle brake button is pressed. ;
; Throttle i/p and o/p display no longer appears when the brake ;
; button is pressed but a throttle test option has been added. ;
; All numerical displays converted to decimal except EEPROM. ;
; Throttle max and min defaults changed to 2Fh and 04h. ;
; Default throttle maps modified to have an active throttle i/p ;
; range of 06h to 30h. ;
; Quick access to Set ID from any top level mode by pressing ;
; both arrow keys together. ;
; RELEASED FOR EXTERNAL EVALUATION TO RICH & COLIN ON 22/02/08 ;
; AND TO SOFTWARE WRITERS ON 23/02/08 ;
; PBPRO17d.ASM ;
; Correct bug that prevented a new race from being started if ;
; an RX_STOP command had not been cleared. ;
; Modify Aux In protocol to use the ms bit of the command byte ;
; to determine if an acknowledge beep should be sounded. This ;
; applies to both long and short commands. ;
; Extra CONFIG option added allowing lane changers to be ;
; disabled for upto 9 secs after the start of a race. ;
; Extra throttle map command added that automatically writes to ;
; EEPROM after send the 16 data bytes. The original throttle ;
; map command just loads the map into RAM so that it can be ;
; to modify the selected map during the race. ;
; EEPROM diagnostic display address navigation improved by ;
; having address increment by 10h every time the start button ;
; is pressed. ;
; Comms diagnostic command (tx_set_read_param_addr) added that ;
; specifies the address of the parameter to be sent in the ;
; Aux Out stream. The parameter address is sent in byte 2 of ;
; Aux Out the stream and the parameter data is sent in byte 5. ;
; To send teh standard Aux Out data stream (byte 2 = 01h and ;
; byte 5 = cars started) set read_param_addr to FFh otherwise ;
; set read_param_addr to the parameter address to be read. ;
; Assembler directive LANG_TYPE added where 0 = English and ;
; 1 = Spanish, Colin got fed up changing it every time. ;
; Corrected throttle map calculation errors for negative dips ;
; in the map. ;
; Corrected bugs in endurance time remaining display at the ;
; start and during a race for the hour display version. ;
; Corrected bugs in digital display of pace car speed and also ;
; prevented manual adjust wrap-around from 0 to 63 with left ;
; key press 63 to 0 with right key press. ;
; Send originator of track call to the PC via the car status ;
; bytes (formally false start bytes) in the Aux Out stream. ;
; Removed brake button as a way of exiting pace car set up mode ;
; and entering speed fine tune mode. ;
; RELEASED FOR EXTERNAL EVALUATION TO RICH & COLIN ON 24/03/08 ;
; AND TO SOFTWARE WRITERS ON 24/03/08 ;
; PBPRO17e.ASM ;
; Simple-H overload and timeout default settings changed to 8A ;
; and 50ms repectively. ;
; Removed code that disabled brake button when pace car was ;
; enabled (this was still effective with a throttle was plugged ;
; in). ;
; Test throttle display changed to show LC and brake ;
; simulataneously. ;
; Spanish translation added to the test throttle screen. ;
; RELEASED FOR EXTERNAL EVALUATION TO RICH & COLIN ON 30/03/08 ;
; AND TO SOFTWARE WRITERS ON 30/03/08 ;
; PBPRO17f.ASM ;
; Various code experiments to investigate PB lockup problem ;
; that occasionally occurs with 1.7, detailed as follows: ;
; a) PCLATH stored in int_pclath at start of iterrupt routine ;
; and restored on exit. ;
; b) Error handling code added for operation_mode jump table ;
; overrun. ;
Volver a “Sistema SSD”
