Escrito originalmente por M1K3LSLOT en 31 de Mayo del 2011
http://www.slotforum.com/forums/index.php?showtopic=55861&st=0
									Wireles, ya llega para SSD
Escrito originalmente por chemari en 31 de Mayo del 2011
Muy buenas noticias... y por lo que veo en el video el aficionado se vuelve a adelantar al fabricante. Deberian de tomar buena nota.... A mi me va ha venir muyyyyy bien este invento.
 A mi me va ha venir muyyyyy bien este invento.- HAL
Escrito originalmente por M1K3LSLOT en 1 de Junio del 2011
El aficionado, siempre se adelanta al fabricante.
Escrito originalmente por RikoRocket en 1 de Junio del 2011
Lane change and brakes now working. This is a very early development, but could be a real possibility soon. Cost will be low compared to Oxigen and Scorpius (these were discussed as an option to get wireless into SSD easily). You will need a computer and to be running SSDC. At this point it works with the C7042 powerbase, but it is likely that it will be able to work in the future with PB-Pro. It will not work with a standard C7030.
Oh, and good news: SSDC version 5 now supports PB-Pro, so download the new software and explore all the new capabilities. This was the version completely rewritten for the C7042. There were many requests to make it compatible with PB-Pro so Andy Wallace has just done this (it was for the UK show). The upgrade cost is £20 GBP. Go to http://ssdc.jackaments.com
Editado 1 de Junio del 2011 por RikoRocket
Escrito originalmente por mahou***** en 1 de Junio del 2011
Genial!, esto me vendría de perlas.
Haber si hay suerte y lo hacen compatible para la PB-Pro, sugún dice Riko es probable, ojalá.
I spoke with Andy about this last night. In principle it would work, it would use the same method as the recorded pace cars control the cars varying the speed. So entirely possible, but this needs to be tried as the feel may not be so good. We will try soon...
Escrito originalmente por mahou***** en 2 de Junio del 2011
						Riko, Do you know if SSDC V5 works on windows 7 64bits?RikoRocket escribió:Mié Jun 01, 2011 8:42 amLane change and brakes now working. This is a very early development, but could be a real possibility soon. Cost will be low compared to Oxigen and Scorpius (these were discussed as an option to get wireless into SSD easily). You will need a computer and to be running SSDC. At this point it works with the C7042 powerbase, but it is likely that it will be able to work in the future with PB-Pro. It will not work with a standard C7030.
Escrito originalmente por chris99 en 5 de Julio del 2011
						Yes it does with no problem.mahou***** escribió:Jue Jun 02, 2011 5:53 amRiko, Do you know if SSDC V5 works on windows 7 64bits?
Escrito originalmente por M1K3LSLOT en 16 de Julio del 2011
Primera prueba del sistema Bluetooth de ssd en ambiente de club y sin imanes en los coches gracias al APB PRO y los chps In-car Pro.
