Escrito originalmente por M1K3LSLOT en 20 de Mayo del 2009
Not if I understand well, a 1.8 F-1 I need four more power settings to not notice much difference between 50% and 100% ie a 75%, 85%, 95%, 100% more Keers.
In this way the differences in behavior of fuel are more real.
Keers brake button is at 100% power or more?
As one can seafty drive car with 7 ID? Keers for 4 seconds, only works if you press brake button.
Reloading Keers 16 seconds.
As simulate worn tires, peak power and very short quick?
La PRO SH de Davidnene
Escrito originalmente por RikoRocket en 20 de Mayo del 2009
If you are having steps then the setting in SSDC is wrong. In tab "Power & Control" use "Throttle based (v1.7+)" - Not "Power Based (v1.6)"
Behavior of fuel are then very real
? With 1.8f and SSDC the fuel adjust becomes infinite and is really really good?M1K3LSLOT escribió:Not if I understand well, a 1.8 F-1 I need four more power settings to not notice much difference between 50% and 100% ie a 75%, 85%, 95%, 100% more Keers. In this way the differences in behavior of fuel are more real.
Escrito originalmente por M1K3LSLOT en 22 de Mayo del 2009
The Ssdc, the factors can vary 50%, 75%, 83%, 100%?
Escrito originalmente por RikoRocket en 22 de Mayo del 2009
No.
With SSDC and PB-ProEsp1.6 the fuel effects can only jump from 50%-75%-88%-100%
With SSDC and PB-ProEsp 1.7 or 1.8 the fuel effects change 50%-51%-52%-53% etc linear. This the same control algorithm and aux protocol that allows the PC to drive a car with full control of the throttle....
No.
woww not work for me becauseRikoRocket escribió:No.With SSDC and PB-ProEsp1.6 the fuel effects can only jump from 50%-75%-88%-100%
