Escrito originalmente por Falcodm en 3 de Marzo del 2008
Hola,
Os queria hacer una pregunta, quiero poner como esclava una PB4 y maestra la PB6Pro 1.6 y la alimentacion de la PB4 es de 15V, ¿si alimento la PB6 con 15V no se dañara? o puedo alimentar una a 12Vx2 y otra a 15V
PB6Pro 1.6 ¿15V?
Escrito originalmente por RikoRocket en 3 de Marzo del 2008
15V for the 6 car PB is possible. There are some components in the lane changers (capacitors) that would not like higher voltages, above 15V is not good.
The standard 4 car power supply is a good match for the maximum current that can be sent by the mosfets, in both 6 car PB and the 4 car PB. So you only need one 15V 4A power supply in the 6 car PB not 2x, and then one 15V 4A in the slave.
The important things for master slave are:
1) always use the same power supply voltage for master and the same voltage for the slave.
2) the slave must be modified to remove the three cylindrical diodes near the power connector.
do NOT use 12V on master and 15V on slave.
Editado 3 de Marzo del 2008 por RikoRocket
Escrito originalmente por Falcodm en 10 de Marzo del 2008
thank you RikoRikoRocket escribió:15V for the 6 car PB is possible. There are some components in the lane changers (capacitors) that would not like higher voltages, above 15V is not good.The standard 4 car power supply is a good match for the maximum current that can be sent by the mosfets, in both 6 car PB and the 4 car PB. So you only need one 15V 4A power supply in the 6 car PB not 2x, and then one 15V 4A in the slave.
